How can I make a 1/2 sec delay in 89c51 using Keil C?
syrax
Full Member level 3
Full Member level 3
i have made a program /blinking led/ but i think its too fast, how can i make a 1/2 sec delay using Keil C
My chip is 89c51 on 4Mhz /i dont know how to calculate a speed/
for (i=0; i<????????; i++){
for(j=0; j<?????; j++);
how to calculate delay in 89c51 using c
use this little application to generate the exact delay u want..it is in assembly code..u can embedded the assembly code in C.
delay in c code in 89c51]
10x it's coll, i try it but have a problem when insert asm i C code
Delay in 89c51
there is asm directive to do so.....looks something like #asm Look in the manual for details....
Re: Delay in 89c51
hi ,
to calculate time, you can never use these "for loops" to adjust accurate timing. you should use one of the timers on board of the 89c51 chip that you use. this is the only way to achieve accurate timing. if you need further help please send me and i'll provide help for using timers.
Re: Delay in 89c51
hi
ezshereef is right, you have 2 timers inside the AT89c51. timer 0 and timer 1, you cane use them to generate very accurate delay or scheduled events, they are easy to use.
keil has simulation to these timers you can use to calculat the delay u want
best regards
Ahmed
