tv tuner card microcontroller
Good evening again to everybody. I completed my research about the Home Theater PC. The system is going to be this ( Note that most of the sites are in GREEK but this should be no problem as the components are …International, and also there are PICTURES so that everybody can see what I mean )
CPU :
http://www.e-shop.gr/show_per.phtml?id=PER.559560
Mobo :
http://www.e-shop.gr/show_per.phtml?id=PER.528365
RAM :
http://www.e-shop.gr/show_per.phtml?id=PER.554189
HDD :
http://www.e-shop.gr/show_per.phtml?id=PER.303756
Video Card :
http://www.e-shop.gr/show_per.phtml?id=PER.513328
TV Card :
http://www.e-shop.gr/show_per.phtml?id=PER.702023
OS :
http://www.e-shop.gr/show_main.phtml?id=PCF.00791
My questions are the above :
1. Is a 450W PSU enough ? Which is the best PSU in your opinion ?
2. Does the system have enough power for me to watch Full HD movies ? ( NOT to record, just to watch them ). If not, what should I change ?
3. What is your opinion about replacing the HDD drive of the HTPC with a Flash Memory unit ?
http://www.e-shop.gr/show_per.phtml?id=PER.553700
( YES, it CAN be bootable through the IDE bus, as long as there is the proper adaptor !! ) :
4. Do you believe that the above kind of equipment generally helps the silence of the PC ? Do I need them for my HTPC ?
http://elektronik.gr/eshop/index.ph...=13790&zenid=df3474eb181afb539ba4d54e56e33c06
http://www.e-shop.gr/show_per.phtml?id=PER.804923
5. The Hauppauge TV card does not have any cooling mechanism. Does it need one ? If so, do these little coolers help ?
http://www.e-shop.gr/show_per.phtml?id=PER.809301
6. Despite the Hauppauge TV card, I only found two others
that combine analog, digital AND satellite TV ( 3 to 1 ). Does anyone know which of the three ( or maybe even another one ) is the best ?
7. Are the above wireless routers good ? ( I want them for the basic stuff, nothing too “heavy” )
http://www.e-shop.gr/show_per.phtml?id=PER.612371
http://www.e-shop.gr/show_per.phtml?id=PER.612372
http://www.e-shop.gr/show_per.phtml?id=PER.612300
8. I have used a special device to read the codes of the Remote control of the Hauppauge TV card. Now I have these codes in my computer. I want to put them in a remote control that I will create myself. Does anybody knows how ? I do not want universal or learnable remotes, I prefer to create something my own, using a microcontroller. How am I going to put the codes inside the microcontroller ? Does anybody have a schematic ?
...And of course some things about the server I also want to make :
10. I want to connect a Usb fingerprint reading device to the Server, that works in VISTA and is reliable. Which of the above ( or maybe another one ) is the best ?
http://accessories.euro.dell.com/sn...k&cs=ukdhs1&l=en&s=dhs&sku=461-10047#Overview
http://www.amazon.com/APC-BIOPOD-Biometric-Password-Manager/dp/B0001V2N62/ref=cm_cr_pr_product_top
http://www.amazon.com/Microsoft-DG2-00002-Fingerprint-Reader/dp/B0002WPSB2/ref=cm_cr_pr_sims_i
http://www.amazon.com/Digital-Privacy-Manager-fingerprint-reader/dp/B000PELLGS/ref=cm_cr_pr_sims_t
http://www.jstac.com/products_a101.htm
http://www.alibaba.com/product-gs/211845272/Live_scan_Sliding_Fingerprint_Reader_Biometric.html
http://www.alibaba.com/product-gs/51682057/FPR_620_Optical_Fingerprint_Reader.html
http://www.alibaba.com/product-gs/51891432/Fingerprint_Reader.html
http://www.alibaba.com/product-tp/100523347/USB_Combo_Fingerprint_Smart_Card_Reader.html
http://www.alibaba.com/product-free/12152094/U_Match_Matchbook_Fingerprint_Scanner.html
http://www.alibaba.com/product-gs/51718997/Fingerprint_Reader.html
http://www.alibaba.com/product-gs/204023994/FPR_201B_Capacitive_Fingerprint_Reader.html
11. I am going to have the above usb fingerprint reading device 10 meters away from the server, and I cannot use a usb wire. So I thought that, since there are some devices called wireless printer servers, which can connect a PC with a usb printer wirelessly, maybe there are some devices that can connect ANY Usb device wirelessly to the PC. So I found the MFP Servers ( Multi Function Print Servers ). Unfortunately, they support multi function jobs, but only for printers that are also scanners and photocopy machines and faxes all together. With them, they do support print, fax & scan, but I am not sure if they work with ANY usb device.
Does anybody know anything about this ?
The MFP Servers that I discovered are the above ( any other device is welcome of course !! ) :
http://www.dealsdirect.com.au/p/airlive-wfp-101u-wireless-multi-function-print-server/
http://www.cens.com/cens/html/en/product/product_main_37087.html
http://www.acquire.co.nz/acquire/default.asp?PageID=ProductDetail&pf_id=1415861&dept_id=1100090
http://www.heise.de/preisvergleich/a263466.html
http://www.ascent.co.nz/productspecification.aspx?ItemID=368797
http://www.taipeitradeshows.com.tw/product_info.shtml;jsessionid=TMvsJGrXBL629GWPPP6c4DHMGm09L9RqDntcKq28l6xPGZ0d6Qyy!-689049336?comno=30922431&showno=2008NSC1015&docno=63952
http://www.amazon.com/gp/product/B0...ails?ie=UTF8&me=&seller=#moreAboutThisProduct
12. Instead of putting case fans in the Server case, do you think that the above solution ( placed next to the Server, of course the case will be wide open ) is good ?
http://www.clevermarket.gr/ViewShopProduct.aspx?Id=49440
13. What do you think about the above devices if I want to cool out a RAID set of hard disks ? Which is better ? ( even something else if you know something )
http://www.e-shop.gr/show_per.phtml?id=PER.650504
http://www.e-shop.gr/show_per.phtml?id=PER.805824
14. The Cat7 wires are compatible with the rest of the Ethernet devices ? Are they worth their price ? If a wire is small, gold plated and shielded, is it SO MUCH better that a usual one, so that I have to buy it ?
For example, I found the above wire :
15. And something else about these wires
o they make just the LAN go faster or they also make the Internet connection faster, if a PC connects to its router through a wire like this ?
16. Last question :
Is this the best router in the world ? Do you know anyone better ( regardless the cost ) ?
http://www.e-shop.gr/show_per.phtml?id=PER.614029
Thank you all in advance for your time. I apologize for my English and my long-long post.
