How can I design an Inverter 6v DC to 6V AC 4Amper?
mf1364
Full Member level 3
Full Member level 3
Hello all
Does any body have schematic for my request ? our can help me how can I do this project ?
An H-bridge will do the job.
Simple configuration:
You may choose to use mosfets instead of transistors. Whichever you can drive to a low enough On-resistance, if you want the load to receive 6V and 4A.
thank you in advance please answer below questions:
1- what is your software ? is it industrial ?
2- what do you mean H-bridge ? do you have any documentation or tutorial to teach me step by step ?
3- Is the out put between A and B branch ? I mean do I have 6v AC between A and B ? and can support 4 ampere ?
4- what is the transistor part number ?
5- how do you have built 60Hz frequency ? with out 555 or micro ?
6- Is this circuit reliable and industrial ?
It is Falstad's interactive animated simulator.
www.falstad.com/circuit
Uses 'generic' components only. Easy to lay out a schematic. Shows current bundles travelling through wires.
It can show several scope traces, although they are not such high resolution as you would see in simulators commonly used in professional circles.
H-bridge describes the arrangement of the switching devices. A letter 'H'.
There are many ways to control the switching pattern. I have not seen a document which discusses them all. You will need to explore various articles and schematics.
The output is the resistor labelled 'load'.
A and B are control signals.
You'll need two NPN's and two PNP's. Or two N-mosfets and two P-mosfets.
They must be rated to carry several amps.
You can use a 555 IC, or any pulse generator you wish, and whatever frequency suits your purpose.
The duty cycle should be 50 percent of course.
Yes, if you construct it with the proper components and the recommended safeguards.
My simple schematic above shows only the essential parts.
Reactions: mf1364
    mf1364
Interesting just knew of the electromagnetic simulator of falstad before. The current showing feature even shows the Back EMF, no, I mean the source to gate voltage between transistor and gate resistor. Thank you for the tip.
There are a bunch of other online simulators: e.g. https://www.circuitlab.com/ or https://www.partsim.com/.
Or other on-/offline tools: LTSpice, et al., see here for a list https://en.wikipedia.org/wiki/List_of_free_electronics_circuit_simulators.
