How can I design a Microstrip Antena 5GHz?! Help
gepard2000
Newbie level 1
antena 5ghz
I want to make a project in microstrip ! 5 GHz! Can you Help me!
microstrip antena
I guess your design isn't going to be specialised (complex shapes or multi layer or etc..etc.), so I would direct you to check Balanis book 'Antenna Theory' Chapter on mictrostrip antennas.
You will find have ever you need (from theory, to simplified design equations) to build a DIY microstrip antenna following simple and easy step by step procedure.
Good luck!
diy microstrip antenna
i think the book on microstrip antenna by james and Hall / microstrip antenna design handbook by Inder and Bahl are two useful books for designer. By, he way i want to know on which substate do u want to print it ?
Added after 59 seconds:
diy microstrip
What is your antenna configuration
1. multilayer?
2. Feeding technique
3. gain and bandwidth requrement
    V
