How can I connect ATMega8535 to Ethernet?
Moof
Full Member level 2
Full Member level 2
Argentina
Atmel has an application note fot make what you want.
my idea is that i want the micro to do encryption to any data trnasmitted through a LAN .The micro will be on the network mideum and can perform some encryption algorithm
very interesting. Do you have any source codes for encryption algorithm?
yes i have a source code of some encryption algorithm but i want to know how to connect the micro to RG45?
Check this great site out with free schematics and source code:
www.ethernut.de
Ethernut
Open Source Hardware and Software
Project for Embedded TCP/IP
Ethernut uses Atmel AVR ATmega128 to connect to Ethernet.
Ethernut PCB Version 2.1 Revision B:
Check out www.avrfreaks.net too. There's a lot of AVR resources and they have their own forum like this one, but only or AVR related topics.
I forgot to mention this project:
eAVR:
It uses AT90S8515 to interface to an cheap old ISA Ethernet card:
Other source h**p://www.laskater.com/projects/uipAVR.htm
