How can I connect an RC snubber to a 3-phase motor?
raman00084
Full Member level 6
Full Member level 6
how to connect rc snubber to 3 phase motor
i am controlling a 3 phase motor through a 3 pole relay. how to connect rc snubber for 3 phase circuit to protect relay contacts.
can i connect like this 1st rc snubber to r phase and neutral 2nd rc snubber to y phase and neutral 3rd to b phase and neutral. ?
regards
kalyan
Re: how to connect rc snubber to 3 phase motor
A delta-connected (phase-to-phase) snubber circuit seem more straightforward because the motor has no neutral terminal at all. But limited voltage rating may suggest a star connected snubber. Both can work.
Generally snubbers for motor relays/contactors are rather unusual and would be only practical for small (e.g. < 100 W) motors.
In general you connect the snubber circuit over the relay contacts, regardless of how many phases you use. The snubber will normally be a capacitor and a resistor in series over the contact.
