How can I beep every 00:00 ?
bianchi77
California
Guys,
I created a clock using DS1307,
How can I beep it everytime it's reaching zero ?
I have created:
//turn on chime
			minute = num2str(ds1307_addr[1]);
			second = num2str(ds1307_addr[0]);
			if ((second =="00") && (minute =="00"))
				  beep_sound_2();
Any ideas ?
thanks
You can't compare a string like that, you have to check each character individually
if ((second[0] =='0') && (second[1] =='0') && (minute[0] =='0') && (minute[1] =='0'))
by the way "minute" and "second" represent the address of the first character of the array , the same as "&minute[0]" and "&second[0]"
I think the second and minute are integer or char variables they cant be a stiring because they are assigned in the above statement so
the exact code shd be
Code C - [expand]
if ((second == 0)  &&  (minute == 0))
like this ?
thanks
char ds1307_addr[7];
	//turn on chime
			minute = ds1307_addr[1];
			second = ds1307_addr[0];
			if ((second ==0) && (minute ==0))
				  beep_sound_2();
That may be so but in the given code there is no definition of these variables and there is a num2str function, if that function doesn't return a string then why is it named like that?
yeah but what are you going to do in beep sound function?? If you just enabled buzzer then It will beep continuously after match 00, so add a else case to make it reset...
or do the both in the beep sound function......
I didnt look on the function names but if it is a function which returns char pointer and second and minute are char pointers then surely it will be like element checking as you mentioned, but the code shown in #4 shd work fine...
