HerohetoChakma
Junior Member level 3
- Joined
- Apr 19, 2013
- Messages
- 30
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Chittagong, Bangladesh.
- Activity points
- 2,338
I need to add a cooler with my program. My Program is in c. I need to on cooler when temperature will exist my set point and it will also stop when temperature will below the set point. My program is given bellow. Could anybody help me please????
#include <16f877a.h>
#include <math.h>
#include "config.h"
//===============configuration==============================
__CONFIG (0x3F32);
//===============define IO port=============================
#define lcd PORTD
#define RS RB4
#define E RB5
#define led1 RB6
#define redled RB7
#define CHANNEL0 0b10000001
#define CHANNEL1 0b10001001
#define buzzer RB2
#define orangeled RB3
#define greenled RB0
//==============FUNCTION PTOTOTYPE=========================
void e_pulse(void);
void delay(unsigned short i);
void send_char(unsigned char data);
void send_string(const char *s);
void send_config(unsigned char data);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void dis_num(unsigned long data);
void increment(unsigned long data);
void read_adc(void);
unsigned short read_temp(void);
void blink_LED1(unsigned char n);
void blink_redled(unsigned char n);
void blink_orangeled(unsigned char n);
void clearrow1(void);
void clearrow2(void);
void clearrow3(void);
void clearrow4(void);
void scancolumn1(void);
void scancolumn2(void);
void scancolumn3(void);
void scancolumn4(void);
void beep_once(void);
//====================MAIN================================
unsigned short result;
unsigned short temp;
float tempB,tempA;
unsigned char keyin[3];
unsigned char num_count=0;
void main(void)
ADRESH=0;
ADRESL=0;
ADCON1=0b11000000;
TRISA=0b11111111;
TRISB=0b00000000;
TRISC=0b00001111;
TRISD=0b00000000;
TRISE=0b00000000;
PORTA=0;
PORTB=0;
CCP1CON==0b00001100;
PR2=0xFF;
T2CON=0b00000101;
CCPR1L=0;
send_config(0b00000001);
send_config(0b00000010);
send_config(0b00000110);
send_config(0b00001100);
send_config(0b00111000);
lcd_clr();
delay(1000);
lcd_goto(0);
send_string("PLEASE ENTER");
lcd_goto(20);
send_string("2 DIGIT SPEC");
while(1)
clearrow1();
scancolumn1();
clearrow2();
scancolumn2();
clearrow3();
scancolumn3();
clearrow4();
scancolumn4();
if(num_count==2)
delay(8000);
lcd_goto(0);
//display character on LCD
send_char(' ');
send_char('S');
send_char('P');
send_char('E');
send_char('C');
send_char('.');
send_char('.');
send_char('=');
lcd_goto(20);
send_char(' ');
send_char('M');
send_char('E');
send_char('A');
send_char('S');
send_char('U');
send_char('R');
send_char('E');
send_char('D');
send_char('=');
while(1)
//keypad value
ADCON0=CHANNEL1;
lcd_goto(9);
keyin[2]=0;
tempA=(keyin[0]-0x30)*10+(keyin[1]-0x30);
dis_num((unsigned long)round(tempA));
send_char(0b11011111);
send_char('C');
send_char(' ');
send_char(' ');
//sensor B the LM35 sensor
ADCON0=CHANNEL0;
lcd_goto(31);
read_adc();
temp=read_temp();
tempB=(((float)temp)*0.48876);
dis_num((unsigned long)round(tempB));
send_char('C');
send_char(' ');
send_char(' ');
if(tempB<tempA)
if((tempB+5)>=tempA)
led1=1;
blink_LED1(10);
greenled=1;
orangeled=1;
blink_orangeled(3);
redled=0;
buzzer=0;
else
led1=1;
blink_LED1(10);
greenled=1;
orangeled=0;
redled=0;
buzzer=0;
else if(tempB>tempA)
led1=1;
blink_LED1(3);
greenled=0;
orangeled=1;
blink_orangeled(3);
redled=1;
blink_redled(3);
buzzer=1;
beep_once();
delay(2000);
// Keypad scanning functions
RC7=0;
RC6=1;
RC5=1;
RC4=1;
RC7=1;
RC6=0;
RC5=1;
RC4=1;
RC7=1;
RC6=1;
RC5=0;
RC4=1;
RC7=1;
RC6=1;
RC5=1;
RC4=0;
if(RC0==0)
while(RC0==0)continue;
if(num_count==0)lcd_clr();
lcd_goto(num_count);
send_char('1');
keyin[num_count]='1';
num_count+=1;
else if(RC1==0)
while(RC1==0)continue;
send_char('2');
keyin[num_count]='2';
num_count+=1;
else if(RC2==0)
while(RC2==0)continue;
send_char('3');
keyin[num_count]='3';
num_count+=1;
if(RC0==0)
send_char('4');
keyin[num_count]='4';
num_count+=1;
else if(RC1==0)
send_char('5');
keyin[num_count]='5';
num_count+=1;
else if(RC2==0)
send_char('6');
keyin[num_count]='6';
num_count+=1;
if(RC0==0)
send_char('7');
keyin[num_count]='7';
num_count+=1;
else if(RC1==0)
send_char('8');
keyin[num_count]='8';
num_count+=1;
else if(RC2==0)
send_char('9');
keyin[num_count]='9';
num_count+=1;
if(RC0==0)
cd_goto(num_count);
send_char('*');
keyin[num_count]='*';
num_count+=1;
else if(RC1==0)
send_char('0');
keyin[num_count]='0';
num_count+=1;
else if(RC2==0)
send_char('#');
keyin[num_count]='#';
num_count+=1;
//==================subroutine LCD setting ==========================
RS=0;
lcd=data;
delay(500);
e_pulse();
void e_pulse(void)
E=1;
delay(500);
E=0;
delay(500);
RS=1;
lcd=data;
delay(500);
e_pulse();
if(data<16)
send_config(0x80+data);
else
data=data-20;
send_config(0xc0+data);
void lcd_clr(void)
RS=0;
send_config(0x01);
delay(600);
unsigned char i=0;
while (s && *s)send_char (*s++);
unsigned char hundred_thousand;
unsigned char ten_thousand;
unsigned char thousand;
unsigned char hundred;
unsigned char tenth;
hundred_thousand = data/100000;
data = data % 100000;
ten_thousand = data/10000;
data = data % 10000;
thousand = data / 1000;
data = data % 1000;
hundred = data / 100;
data = data % 100;
tenth = data / 10;
data = data % 10;
if(hundred_thousand>0)
send_char(hundred_thousand + 0x30);
send_char(ten_thousand + 0x30);
send_char(thousand + 0x30);
send_char(hundred + 0x30);
send_char(tenth + 0x30);
send_char(data + 0x30);
else if(ten_thousand>0)
else if(thousand>0)
else if(hundred>0)
else if(tenth>0)
else send_char(data + 0x30);
unsigned short j;
for(j=10;j>0;j--)
{ lcd_goto(32);
data=data+1;
dis_num(data);
delay(10000);
//==================subroutine ADC=========================
void read_adc(void)
unsigned short i;
unsigned long result_temp=0;
for(i=2000;i>0;i-=1)
ADGO = 1;
while(ADGO==1);
result=ADRESH;
result=result<<8;
result=result|ADRESL;
result_temp+=result;
result = result_temp/2000;
temp=result;
return temp;
//==================subroutine DELAY==========================
for(;i>0;i--);
//==================led blinking============================
//loop for n times
for(n+=1;n>0;n-=1)
//set LED1 to 1
led1=1;
//short delay
for(unsigned int i=0;i<20000;i+=1);
//set LED1 to 1
led1=0;
//short delay
//function to blink redled for n times
//loop for n times
for(n+=1;n>0;n-=1)
//set redled to 1
redled=1;
//short delay
//set redled to 1
redled=0;
//short delay
//loop for n times
for(n+=1;n>0;n-=1)
//set redled to 1
orangeled=1;
//short delay
//set redled to 1
orangeled=0;
//short delay
//==================Buzzer Beeping============================
buzzer=1;
delay(10);
buzzer=0;
delay(20);
buzzer=1;
delay(10);
buzzer=0;
In this program LED and Buzzer will beep when temperature will exist my set point but i want also a cooler to add with this program.
#include <math.h>
#include "config.h"
__CONFIG (0x3F32);
#define lcd PORTD
#define RS RB4
#define E RB5
#define led1 RB6
#define redled RB7
#define buzzer RB2
void e_pulse(void);
void lcd_clr(void);
float tempB,tempA;
void main(void)
ADRESH=0;
ADRESL=0;
ADCON1=0b11000000;
TRISA=0b11111111;
TRISB=0b00000000;
TRISC=0b00001111;
TRISD=0b00000000;
TRISE=0b00000000;
PORTA=0;
PORTB=0;
PR2=0xFF;
T2CON=0b00000101;
CCPR1L=0;
lcd_clr();
delay(1000);
lcd_goto(0);
lcd_goto(20);
while(1)
clearrow1();
scancolumn1();
clearrow2();
scancolumn2();
clearrow3();
scancolumn3();
clearrow4();
scancolumn4();
if(num_count==2)
delay(8000);
lcd_goto(0);
send_char(' ');
send_char('S');
send_char('P');
send_char('E');
send_char('C');
send_char('.');
send_char('.');
send_char('=');
lcd_goto(20);
send_char(' ');
send_char('M');
send_char('E');
send_char('A');
send_char('S');
send_char('U');
send_char('R');
send_char('E');
send_char('D');
send_char('=');
while(1)
//keypad value
ADCON0=CHANNEL1;
lcd_goto(9);
keyin[2]=0;
send_char('C');
send_char(' ');
send_char(' ');
ADCON0=CHANNEL0;
lcd_goto(31);
read_adc();
temp=read_temp();
send_char('C');
send_char(' ');
send_char(' ');
if(tempB<tempA)
led1=1;
blink_LED1(10);
greenled=1;
orangeled=1;
blink_orangeled(3);
redled=0;
buzzer=0;
else
led1=1;
blink_LED1(10);
greenled=1;
orangeled=0;
redled=0;
buzzer=0;
led1=1;
blink_LED1(3);
greenled=0;
orangeled=1;
blink_orangeled(3);
redled=1;
blink_redled(3);
buzzer=1;
beep_once();
delay(2000);
RC7=0;
RC6=1;
RC5=1;
RC4=1;
RC7=1;
RC6=0;
RC5=1;
RC4=1;
RC7=1;
RC6=1;
RC5=0;
RC4=1;
RC7=1;
RC6=1;
RC5=1;
RC4=0;
if(RC0==0)
send_char('1');
num_count+=1;
else if(RC1==0)
send_char('2');
num_count+=1;
else if(RC2==0)
send_char('3');
num_count+=1;
if(RC0==0)
send_char('4');
num_count+=1;
else if(RC1==0)
send_char('5');
num_count+=1;
else if(RC2==0)
send_char('6');
num_count+=1;
if(RC0==0)
send_char('7');
num_count+=1;
else if(RC1==0)
send_char('8');
num_count+=1;
else if(RC2==0)
send_char('9');
num_count+=1;
if(RC0==0)
cd_goto(num_count);
send_char('*');
num_count+=1;
else if(RC1==0)
send_char('0');
num_count+=1;
else if(RC2==0)
send_char('#');
num_count+=1;
RS=0;
lcd=data;
delay(500);
e_pulse();
void e_pulse(void)
E=1;
delay(500);
E=0;
delay(500);
RS=1;
lcd=data;
delay(500);
e_pulse();
if(data<16)
else
data=data-20;
void lcd_clr(void)
RS=0;
send_config(0x01);
delay(600);
unsigned char i=0;
data = data % 1000;
data = data % 100;
tenth = data / 10;
data = data % 10;
else if(thousand>0)
else if(hundred>0)
else if(tenth>0)
unsigned short j;
for(j=10;j>0;j--)
{ lcd_goto(32);
data=data+1;
dis_num(data);
delay(10000);
void read_adc(void)
unsigned short i;
ADGO = 1;
while(ADGO==1);
result=ADRESH;
result=result<<8;
temp=result;
return temp;
for(;i>0;i--);
//loop for n times
for(n+=1;n>0;n-=1)
//set LED1 to 1
led1=1;
//short delay
//set LED1 to 1
led1=0;
//short delay
//loop for n times
for(n+=1;n>0;n-=1)
//set redled to 1
redled=1;
//short delay
//set redled to 1
redled=0;
//short delay
//loop for n times
for(n+=1;n>0;n-=1)
//set redled to 1
orangeled=1;
//short delay
//set redled to 1
orangeled=0;
//short delay
buzzer=1;
delay(10);
buzzer=0;
delay(20);
buzzer=1;
delay(10);
buzzer=0;
