[SOLVED] how can C code access device driver?
spartekus
Member level 5
Duisburg, Germany
Hi everyone,
i want to write a device driver (in linux), which has functions such as "write_memory" "read_memory", but i want to decide in C, when these functions will work.
How can C code control device driver?
thanks a lot!
best regards
The C code can control the devices. The only requirement is you should write the code for kernel space.
thank you srizbf
do you know any link for tutorial or example, i can read more about it? It would be so usefull.
Hello spartekus. A driver for what device? Do you want to develop a driver or do an API? There is a different. The device driver is a layer interface between the hardware and an aplication like SO and an API it's an interface layer which brings abtraction to programers
