ama_trig
Full Member level 2
- Joined
- Oct 9, 2009
- Messages
- 123
- Helped
- 20
- Reputation
- 40
- Reaction score
- 13
- Trophy points
- 1,298
- Location
- Where my hard drive lives!
- Activity points
- 2,100
Testing power supply
Under what conditions, power supplies are tested, and are considered qualified?(every kind of power supply )
For example if power supply is rated at 5v300mA , if it has a transformer, it means when there is a 300 mA load, you should have 5v across the PSU? while it might have 8v under no load, and if it's switching its always 5v until max 300mA is reached?
I came across some circuit which was pretty odd to me (the design style) I was wondering if this was a safe design and will always result in the same voltage over same provided input or not.
My whole idea was to use same approach by using a pwm ... to make a variable psu.
https://www.electronics-lab.com/projects/power/020/mcu_power_supply_schematic.png
Digital Multiple Voltage Power Supply
