How a transistor can be used to switch between 2.5V and 5.0 volts ?
syed intisar haider
hello all
my question is that how a transistor can be used to switch between 2.5V and 5.0 volts
plz help me in this regard
what wil be input and how its functions guve me the actual cct diagram i know it is simple but i m unable to do it
take care
Re: transistor switch
BIAS THE TRANSISTOR IN SATURATION REGION AND CUTOFF REGION....IN CUTOFF REGION TRANSISTOR WILL BE IN "ON" STATE FOR SATURATION IT WILL BE CONSIDERED AS IN "OFF" STATE ... PLZ REMOVE THE LINEAR REGION FOR MAKING TRANSISTOR AS A SWITCH
HOPE IT SOMEWHAT ENLIGHTENS YOU
transistor switch
thx kumar
can u give the cct diagram for this i wil be highly thankfull to u in this regard
transistor switch
I'm agree with electronics_kumar with the notice that on saturation region the output will go to 0.2V,if u take the output on the collector, so u must split the resistance on the collector in two resistance, so that on saturation R2*Ic_sat=2.5V...
see the attchement..
regards
transistor switch
for bjt you have to control right biasing of both junstors - c-b and b-e . But for symmetric mosfet based switches it not as strict as for bjt . If collector - emitter voltage polarity can be reversed - consider to use mosfet based switches . Look to Vishay they have good switches with very low impedances
