HopeRF's RFM69W RF module compliance
nanorobot
Newbie level 6
Newbie level 6
Hi
There is an RF module ( **broken link removed** ). The module's datasheet on page 8 clearly states that it complies with ETSI regulatory requirements. On manufacturer's site there are also measurement reports (RFM69W-869 ETSI Testreport), based on which I have certain doubts if it is compliant. Well, from the 869-H.pdf and 869-V.pdf it appears that between 800 MHz and 900 MHz there are additional spikes above the compliance line . Am I missing something? Thank you for your reply.
There might be a "Bandwidth Definition" in this measurement.The limits would consider "out of band spurs".
Since we don't know that Bandwidth, we cannot say anything.
For instance, if bandwidth is 30MHz (I guess) in this case output spectrum seems to be clean in according with this specification.
The measurement conditions should be known first.
