hold time is negative value?
aifi
Member level 2
Member level 2
what happen if hold time is negative? what happen to our slack value?:?:
if the hold is negtive. the data is arraving very fast berfore the clock.so we have to insert the data delay buffer.
hi,
that's mean it's a wrapper contain a register, so it's negative .
hi..
is that negative symbol just to show us that it is a hold time and positive for setup time?
if i have negative value for hold time in my library, is it correct to use the following formula to calculate slack:
slack(hold time) = arrival time - requered time
*i use BUILDGATES for synthesis
Maybe you can change your clock skew for solving it.
To get positive slack for hold time can we also increase input delay ??
Dr.farnsworth
This was discussed in this board. See:
Regards
Z
what tool are you using?
what command u perfomed to get the negative hold time?
hold time requirement?
negative hold time occus when the datapath delay is greater than
clock path delay.
best regards
