ifryd
Newbie level 5
Hi I want to design high voltage source. I need to obtain source with variable frequency output of high alternating voltage.
The most desired circuit is this one:
but here are the questions:
1) How to design it to obtain on secondary winding variable high voltage. I want to get spikes of +HV and -HV on the same output. (one pin ground, second pin with changing +HV, -HV)
Circuit from the link gives spikes only in one direction...
2) Would be good to use these flyback transformers on slow frequencies such as from 200Hz to 2000Hz? Most designers say these circuit should operate on 17KHz? Apart from that I found transformer manufacturer who state that his transformers should work with range of frequency : 15- 60kHz
High Voltage Transformers
Adam
Adam
