I have a serious problem which occurs randomly.
I have a low voltage 5v section with a LM555 set to "one shot" which means when i press a switch, the 555 output goes high for X miliseconds.
the 555 output goes to an optocoupler that ignites a trigger coil (ignition coil) and the coil should ignite a Xenon lamp.
the problem is, when i trigger the 555, on the scope i can see that the output rises immediately to about 4-5v, but after 50 uSec, it has a big spike downwards, even lower than 0v, and it recovers again very quickly to the high level.
the thing is, that i randomly have the flash about 100ms after triggering the 555. most of the times the flash happens immediately, but about 1 time every 20 triggers, the flash fires in some 100ms delay.
What i believe is happening, that the primary High voltage pulse is creating bad stuff on the 555, causing the spike downwards, which is causing maybe randomly the optocoupler not to fully turn on enough time, and only after the 555 output recover the spike downwards, it rises again and turns on the optocoupler fully again which triggers the lamp in delay.
both the Xenon lamp and the 555 share the same ground. they have to.
the 555 is powered via L7805 from a 12v battery which is also charging the high voltage capacitors.
on lower voltages of the xenon flash and trigger it happens much less often.
any idea how to reduce the spike or make the 555 immune to the spike ?
I already have plenty of 10uF ceramic bypass capacitors all around. tried even on the 555 output, no help...
Thanks for your replies
