I want to build analog to digital circuit with 100 volt as reference volt
I tried to use R/2R circuit , it work will but with input volt (100v)
Now I want to control by microcontroller
How I can to do it ??
You just need a high voltage op amp and a high voltage supply.
You could use the LTC6090 for example.
It can generate a 0-100V output from a 0-5V input with +100V and -5V supply voltages by using a non-inverting gain of 20.
See Ltspice simulation below:
before designing an amplifier you should give some informations:
* frequency range
* maybe settling time
* output current
Other requirements, like:
* noise
* size
* cost
* power supply
* load behaviour (pure resistive, or complex)
* you need push/pull or is high side drive sufficient?
* part availability
