High-to-low level shifter
IADanilov
Member level 3
Moscow, Russia
high to low level shifter
Hi all!
I need circuit which shift signal from 3.3 V supply to 1.8 V. I have two type of transistors: for 3.3 V and for 1.8 V. Can I use as level shifter inverter which operates at 1.8 V supply and consist of 3.3 V transistors?
The simplest thing you can do is cascade two inverters together. The first inverter will use 3.3V transistors, operating off a 3.3V supply. The second inverter will use 1.8V transistors operating off a 1.8V supply.
The only thing you have to be careful of are input/output levels (V_OH, V_OL, V_IH, V_IL). Ensure that the signals are all within spec.
1.8v to 3.3v level shifter
U can use the balance level shifter or traditional one like inverter out is given to the cascaded nmos and pmos as a input and the output is given to the inverter.
level shifter 1.8 3.3
    V
1.8v level shifter
Two (1P & 1N) HV (3.3V) mos and 1 LV (1.8V) inverter can get this job done easily.
@colibaidh
The circuit you have given, gives inverted output
LOGIC 1 = 3.3V gives LOGIC 0 (1.8V) and
LOGIC 0 = 3.3V gives LOGIC 1 (1.8V) and
Interchange the connections of two 3.3V NMOS to get rid of the problem
Thanks
Vikram
Re: level shifter 1.8 3.3
can you explain the above given circuit in detail
