Hi all I began programming in High TECH C recently. I made an easy code in order to test myself. E.g. my count increases with every passing 5 seconds. The code works well.
Now I want to use EEPROM to save the data in every 500 counts. Then even if there is an power down it will not lose all the data.
*What should I do in order to succeed this in High TECH C?
*I want to make EEPROM to overwrite the data on the previous data? E.g. when the value on EEPROM 5, it will erase it and write 6 on the next 500 counts. Can i do this?
*At last I am not very familiar with activating EEPROM and etc. on High TECH can u give me hints about registers?
Thank you for your care..
