AmanNVI
- Joined
- Dec 17, 2012
- Messages
- 7
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Location
- Sacramento, CA
- Activity points
- 1,339
Hi gents,
I have a current signal from a detector (PMT) which is being sampled once every 2 to 2.4 nS.
The current output from my detector ranges from 0-2 mA.
The current input on my A/D converter / op amp expects a 0-10mA signal. The voltage values range from 5 - 25V of PMT output.
I can't change the detection electronics, so I was thinking I could use a simple collector-base transistor setup to increase the current (common collector design) like this one (on right)
http://www.sciencelobby.com/junction-transistors/common-collector-amplifier.html
I tried a setup using an NPN for this - but it inverted and amplified the current signal. I guess this makes sense as I think this is a "Class A" amplifier.
So my question is, is this the best way of achieving high speed low gain amplification of current? If yes I can add another transistor, and re-invert the signal. If there's a better way, i.e. an op-amp or low gain amp that will keep up with the speed needed, I'd go for it. My major concern is that I don't want to reduce the signal quality from the PMT. This is for a very low light laser scanning application, so signal quality is of top priority.
I apologize in advance of my questions are lacking a deep understanding here - I know enough only to be dangerous
Any advice is greatly appreciated!
