gmarocco
Junior Member level 1
I have built a high side switch using bjt: the circuit is powered with 18V and the base of the NPN transistor is driven by a pulse between 0 and 5V I would like to use a 50mA load. The circuit is in the image attached to the post.
The load is powered only if I remove resistor R1
Here are the calculation I have done:
Ib(Q3) = 5mA as Ic/Ib=10 in saturation
Hypotesys: Ic(Q4)=4mA
R3= Vbesat(q3)/9mA = 0.9V/0.009 = 100 Ohm
R2 = (18- Vbesat(q3)-Vcesat(q4))/4mA = 4.2kOhm
R4 = (5-Vbesat(q4))/600uA = 7.3kOhm
R3 = 0.6V/200uA = 3kOhm
What's wrong with these calculations?
Many thanks
Many thanks
