T
treez
Hello
We are wanting to use the BTS6163 high side smart FET.
Please could you help interpret the datasheet..?
BTS6163 smart FET datasheet
https://www.infineon.com/dgdl/Infin...n.pdf?fileId=db3a3043183a95550118606cdf2336a2
Page 3 says that turn-ON slew rate of output voltage is 0.65V/us, but it also says that it gets to 90% of Vout in 150us……Do you know which is it to be?
The first page says it has a “nominal current” of 5.5A, but then page 3 gives “RON” spec at 7.5A.
Also page 3 says that RthJC is only 1.1K/W, so why on earth is the “nominal current” stated as being just 5.5A? [Rds(on) is only 38 milliohms]
