High-side P N FET driver resistor
Pha5e
Full Member level 1
I am not here - it's an illusion
In a high side driver configuration consisting of a P-type FET for the pass function and an N-type FET for the switching function, how do I calculate the value of the pull-up resistor which connects the gate of the pass transistor to the source (input supply)?
It's mainly a function of the switching speed you need. That resistor has to charge the gate capacitance of the P-MOSFET to turn it off, so the smaller the resistor, the faster it can turn off. Of course the smaller the resistor, the more power is dissipated when the P-MOSFET is ON. So the trade-off is between turn-off speed and power.
Reactions: Pha5e
    Pha5e
Is there a formula I can use to calculate an optimal value for the resistor based on the figures in a datasheet?
Most application notes I read seem to mention between 1k and 10k?
As I said, it depends upon the switching speed you need. Do you know what that is? What is the P-MOSFET you want to use?
It's just to power on a wireless module from a micro-controller. The switching speed does not need to be high.
In that case you can use a high value of resistor to minimize power if you want, limited mainly by leakage from the P-MOSFET gate and the off leakage of the N-MOSFET. You could likely use 100kΩ or even higher.
