R
red_alert
I'm trying to avoid an isolate power supply for the high-side switches (MOSFET full bridge) so I came up to the only remaining options: bootstrap technique or a charge pump.
The problem is that I need a powerful power supply as I'm going to use high current MOSFET drivers (TC4452 - 12Amps).
I have the possibility to use a bootstrap circuit (as I could limit the duty cycle to 95% or something) but then I need to use quite a bunch of high pulse bootstrap capacitors and a high current ultrafast diode which might become too bulky for my space requirements.
I'd prefere a charge pump circuit but I don't know how to reference its output voltage to the high-side MOSFET source (as its voltage will fluctuate between ground and DC bus). I've seen a few implementations (NE555) but they are low current only. They use a simple resistor to shift the voltage but I need something more efficient (maybe a current source?).
I really need some help here - I spent few days on google with no success.
