Coza
Newbie level 2
I've been looking to make a constant current circuit of 6.5A at 14V (looking to reconfigure for 4A as well).
I have tried using a darlington pair to limit the current flow. This was controlled by a shunt resistor and sense points feeding in to a op-amp current amplifier. I am confident this works fine. The current amplifier then feeds in to an op amp current comparitor and using a reference voltage (2.5V). From here is where I think I am getting a little stuck.
My current comparitor feeds into a base of an npn transistor with the emitter to ground. At the point the current comparitor reaches the desired current I want the npn transistor to start switching and turning the darlington pair off to reduce the current.
So far upon testing the whole circuit works fine up until I look at adjusting a constant resistance load. I still seem to be able to draw more than my desired current.
Have I missed anything obvious?
Many thanks
Many thanks
