d123
Advanced Member level 5
Re: High power capacitave voltage doubler topology
I think, if I've understood, that what you may want to look into is PFC about the diode propagating to the grid.
A typical start-up inrush current-limiting circuit is a series resistor in parallel with a MOSFET. The resistor deals with the initial spike, then the lower resistance MOSFET is used as the path from source to load (supply to Dickson/Dickinson charge pump). Sorry if I'm missing the point about anything.
