Aemornion
Newbie level 3
- Joined
- Sep 17, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 40
Hello Everyone,
I joined this forum in the hopes obtaining some circuit design assistance relating to fiber optic Transmitters and Recievers.
I have obtained some higer end Rx/Tx units and I am having some difficulty figuring out how to drive them.
I am tryng to drive Serial (9600) data through them.
Their are various reasons I am not converting to RS232 and then fiber. The most prominant is power requirments and space.
I was able to get this to work with the low end industrial fiber Rx/Tx modules. But in the end result I am forced to use 1350 and 1550 nm fiber forcing me to acquire these particular modules.
The end result will be a microcontroller running inside a high voltage test unit. Which has existing fibers I need to maintain.
I have attached the data sheets for the Tx/Rx modules.
I have a pretty good grasp on the Tx module.
It has a reverse photo diode, So i was planning on using a bjt tied to a differential opamp.
The signal is input via a NAND gate to a voltage divider, and decoupling cap to the cathode of the laser. When the signal is active the laser cathode will fall low, allowing for a current to flow. Then that current is regulated by a BJT. the regulation occures via the reverse photodiode, is compared to a reference via a differential op-amp and output to the bjt to maintan a constant laser power.
Does this seem sane?
For the Rx module I am lost
It has 5 pins
#1 VR : PD bias
#2 OUT+ : Positive output
#3 OUT- : Negative output
#4 Vdd : Preamp bias
#5 GND : Case ground
I would prefer to get it to a single output and not a differential output.
But I am lost in how to go about properly biasing the preamp and photodiode etc.
Any help/suggestions are greatly appreciated.
My data rate does not need to be astronomically high, All I am trying to to is read voltage and temp data. but later we might try and add more functionality. So keeping it with a digital communication like serial would be preferable.
Thank you for any help and assistance which is offered.
Cheers
It has 5 pins
#1 VR : PD bias
Cheers
