dann11
Full Member level 3
Hi! I am designing a PFC circuit(in boost configuration, inductor is CCM, switching frequency is 100kHz), and it has a high current spike during on and off of the MOSFET switch. I used a bulb as its load. I am not sure if these high spikes are results of the MOSFET parasitic noise or a common mode noise injected at the input of the PFC circuit ? And how should I work out on these noise? should I add a snubber circuit? or should I adjust the capacitance value of my input filter? or the inductance value of the EMI filter? I have attached the test result for your reference.View attachment F0074TEK.BMP
