if these resistor are to balance the current flow is it good to add fuse instead of resistor so if there is any high spike in current or voltage fuse should blow off....?
hi BradtheRad i want to design 10-16amp. if i only use tr2-tr4 is it all right without changing the rest of the design?? 8,8 amps each transistor??
