MouradR
Junior Member level 1
Hi There,
I have a circuit board with 9 loads (assume resistors) and each load is connecting to the input source (Sinusoidal signal) via toggle switch. so, now I've got 9 toggle switch to switch on/off
the loads. The problem is now I want to extend the number of loads to be 16 or 32 etc.. and it is not practical to have toggle switch for each load. I want to use something like de-
multiplexer or programmable switch array but the issue is that each load draws up to 2amp and voltage around 100V peak to Peak so, IC won't be able to stand the high voltage/current.
Any Help will be much appreciated!
Thank you
-MRN
Thank you
-MRN
