Hi Tech C PICC v9.83 Optimization Problem
Advanced Member level 6
Bangalore, India
Hello!
I am using Hi Tech C Pro PICC v9.83 compiler to compile my c codes for PIC 10/12/16 MCUs. Please see the attached image. In that if I check the Assembler option and compile the compiler is creating wrong hex file (LCD code doesn't work). If I uncheck the Assembler option and compile it is creating the right hex. I tried reinstalling the compiler but it doesn't make any difference. What might be the problem? Am I getting optimized code without selecting the Assembler option?
Thanks
Jayanth D
The optimization of code can inadvertently remove portions of the code which the compiler interprets as without purpose, such as software delay routines, trivial/empty loops, etc.
Therefore optimization can lead to unexpected results if such routines are not handled correctly.
Without seeing your code it is difficult to ascertain the exact issue.
BigDog
The code is like this
// ===== SMART GROUP ======
// LCD display with the motor
// LCD display is to show the direction of the motor
// PORT B and PORT C is for motor
// PORT D is for LCD display
//#include <pic.h>
#include <string.h>
#include <htc.h>
__CONFIG(0x3f32); //3FFB
#define _XTAL_FREQ 20000000
//=========== define of the motor ports ============
#define L293D_E 	RA0         //Enable of L293D
#define L293D_A 	RB1         //Positive of motor
#define L293D_B 	RA2         //Negative of motor
#define L293D_C 	RA3			//Positive of motor
#define L293D_D 	RB2			//Negative of motor
#define L293D_G		RA5		    //Positive of motor
#define L293D_H 	RE0			//Negative of motor
#define L293D_J		RE1			//Positive of motor
#define L293D_K 	RE2			//Negative of motor
//=========== define the LCD ports =================
#define	rs			RB7				//RS pin of the LCD display
#define	e			RB6				//E pin of the LCD display
#define	lcd_data	PORTD			//LCD 8-bit data PORT
//=========== define LED Signal Light =============
#define signal_left  RB5			//Left side LED
#define signal_right RB4			//Right side LED
//=========== define Buzzer ================
#define buzzer		 RB3				//Buzzer
//=========== define switch ===============
#define	switch1		RC0 		//Switch 1 for LENG KABIAN
#define	switch2		RC1 		//Switch 2 for LENG KABIAN
#define	switch3		RC2 		//Switch 3 for LENG KABIAN
#define	switch4		RC3 		//Switch 4 for LENG KABIAN
#define	switch5		RC4 		//Switch 5 for LENG KABIAN
#define	switch6		RC5 		//Switch 6 for LENG KABIAN
#define	switch7		RC6 		//Switch 7 for LENG KABIAN
#define	switch8		RC7 		//Switch 8 for LENG KABIAN
//========== Motor Function Prototypes ===================
void rotate_forward_LCD_1(void);       	  	//Forward run function
void rotate_backward_LCD_1(void);         	//Backward run function
void rotate_leftside_LCD_1(void);	  	  	//Leftside run function
void rotate_rightside_LCD_1(void);    	  	//Rightside run function
void rotate_forward_LCD_2(void);		  	//Forward run function
void rotate_backward_LCD_2(void);		  	//Backward run function
void rotate_leftside_LCD_2(void);		  	//Leftside run function
void rotate_rightside_LCD_2(void);		  	//Rightside run function
void breaks_1(void);        		  		//Motor stop function
void breaks_2(void);  		 		  		//Motor stop function
void breaks_3(void);        		  		//Motor stop function
void breaks_4(void);  				  		//Motor stop function
void delay_motor(void);            		  	//Some delay (Motor)
void delay_led(void);						//Some delay (LED)
void delay_buzzer(void);					//Some delay (Buzzer)
void command_error(void);					//Command error
//======== LCD Function Prototypes =========
void delay_lcd(unsigned long data);
void send_config(unsigned char data);
void send_char(unsigned char data);
void lcd_goto(unsigned char data);
void lcd_clr(void);
void send_string(const char *s);
// ======= UART Function Prototypes =======
void uart_send(unsigned char data);
unsigned char UART_Receive_Char(void);            //receive uart value
unsigned char UART_Receive_String(void);
void uart_str(const char *s);
//======= LED Signal LED ==========
void led_off_l(void);
void led_off_r(void);
void led_signal_left(void);
void led_signal_right(void);
void led_signal_sos(void);
void led_sos_off(void);
//========== Buzzer Function Prototypes ======
void buzzer_stop(void);
// ========== Program Start ==============
unsigned int count = 0, count1 = 0;
unsigned char myString[4];
void interrupt ISR(void)
	if(RCIF)  //If UART Rx Interrupt
		if(OERR) //if over run error, then reset the receiver
			CREN = 0;
			CREN = 1;
		if((RCREG == 'L') || (RCREG == 'R') || (RCREG == 'U') || (RCREG == 'D') || (RCREG == 'X') || (RCREG == 'B')){
			myString[count] = RCREG;
			count++;
			if(count == 2) count = 0;
			count1 = 0;
		else if((RCREG == 'S') || (RCREG == 'O')){
			myString[count1] = RCREG;
			count1++;
			if(count1 == 3) count1 = 0;
			count = 0;
		if((RCREG == 'L') || (RCREG == 'R') || (RCREG == 'U') || (RCREG == 'D') || (RCREG == 'X')){
			count++;
			count1 = 0;
			if(RCREG == 'S'){
				//if((myString[0] == 'L') || (myString[0] == 'R')){
					if(count == 1) {
						count = 0;
						count1 = 0;
					else if((count1 == 0) || (count1 == 2)) {
						count1++;
						count = 0;
			else if(RCREG == 'O'){
					if(count1 == 1) {
						count1++;
						count = 0;
		RCIF = 0;
// ===========  MOTOR CODING ============
void rotate_forward_LCD_1(){
        L293D_A = 1;             				//Make positive of motor 1
        L293D_B = 0;             				//Make negative of motor 0
        L293D_E = 1;             				//Enable L293D
		unsigned long delay_time=5000;
		//setup ADC
		//ADCON1 = 0b00000110;					//set ADx pin digital I/O
		//configure lcd
		send_config(0b00000001);				//clear display at lcd
		send_config(0b00000010);				//lcd return to home
		send_config(0b00000110);				//entry mode-cursor increase 1
		send_config(0b00001100);				//display on, cursor off and cursor blink off
		send_config(0b00111000);				//function set
		//display startup message
		lcd_clr();								//clear lcd
		lcd_goto(5);							//set the lcd cursor to location 0
		send_string("PSM.L");					//display "Cytron Tech."
		lcd_goto(27);							//set the lcd cursor to location 20
		send_string("UP");						//display "SK40C"
void rotate_backward_LCD_1(){
        L293D_A = 0;            				//Make positive of motor 0
        L293D_B = 1;             				//Make negative of motor 1
		//setup ADC
		//configure lcd
		lcd_goto(25);							//set the lcd cursor to location 20
		send_string("DOWN");					//display "SK40C"
void rotate_leftside_LCD_1(){
        L293D_C = 1;             				//Make positive of motor 1
        L293D_D = 0;             				//Make negative of motor 0
		//setup ADC
		//configure lcd
		send_string("LEFT");					//display "SK40C"
void rotate_rightside_LCD_1(){
        L293D_C = 0;             				//Make positive of motor 0
        L293D_D = 1;             				//Make negative of motor 1
		//setup ADC
		//configure lcd
		send_string("RIGHT");					//display "SK40C"
void rotate_forward_LCD_2(){
        L293D_G = 1;             			//Make positive of motor 1
        L293D_H = 0;             			//Make negative of motor 0
		//setup ADC
		//configure lcd
		send_string("PSM.R");				//display "Cytron Tech."
void rotate_backward_LCD_2(){
        L293D_G = 0;             			//Make positive of motor 0
        L293D_H = 1;             			//Make negative of motor 1
		//setup ADC
		//configure lcd
void rotate_leftside_LCD_2(){
        L293D_J = 1;             			//Make positive of motor 1
        L293D_K = 0;             			//Make negative of motor 0
		//setup ADC
		//configure lcd
void rotate_rightside_LCD_2(){
        L293D_J = 0;             			//Make positive of motor 0
        L293D_K = 1;             			//Make negative of motor 1
		//setup ADC
		//configure lcd
void command_error(){
		buzzer=1;
		//setup ADC
		//configure lcd
		send_string("COMMAND");				//display "Cytron Tech."
		send_string("ERROR");				//display "SK40C"
void breaks_1(){
        L293D_E = 0;             //Disable L293D
void breaks_2(){
void breaks_3(){
void breaks_4(){
void buzzer_stop(){
		buzzer=0;
// ======== LED Signal Light ==========
void led_signal_left()
		signal_left=1;
		//setup ADC
		//configure lcd
		send_string("SIGNAL");					//display "Cytron Tech."
void led_signal_right()
	signal_right=1;
	//setup ADC
	//configure lcd
void led_signal_sos()
	signal_right=1;
	signal_left=1;
	//setup ADC
	//configure lcd
	lcd_goto(3);							//set the lcd cursor to location 0
	send_string("EMERGENCY");					//display "Cytron Tech."
	lcd_goto(23);							//set the lcd cursor to location 20
	send_string("EMERGENCY");					//display "SK40C"
void led_off_l()
	signal_left=0;
void led_off_r()
	signal_right=0;
void led_sos_off()
	signal_left=0;
	signal_right=0;
// ========= TIME DELAY ============
void delay_motor(){                			//delay for motor
    unsigned char i,j,k;
    for(i=0;i<0x20;i++)
        for(j=0;j<100;j++)
                for(k=0;k<100;k++);
void delay_led(){
    for(i=0;i<0x20;i++)
        for(j=0;j<255;j++)
                for(k=0;k<255;k++);
void delay_buzzer(){
    for(i=0;i<0x20;i++)
        for(j=0;j<150;j++)
                for(k=0;k<150;k++);
void main(){                 		  //Our main function
	TRISA=0x00;					      //One side of Motor
	TRISB=0x00;						  //LCD and Buzzer
	TRISD=0x00;						  //LCD display
	TRISE=0x00;						  //One side of Motor
	PORTA=0;						  //Switch
	PORTB=0;
	PORTD=0;
	PORTE=0;
	TRISC=0xFF;						  //Switch
	PORTC=0;						  //Switch
	ADCON1 = 0b10000111;
	CMCON = 0b00000111;
	CVROE = 0;
	//Configure UART
    SPBRG=129;            //set baud rate as 9600 baud
    BRGH=1;                //baud rate high speed option
    TXEN=0;                //disable transmission
    TX9 =0;                //8-bit transmission
    RX9 =0;                //8-bit reception
    CREN=1;                //enable reception
    SPEN=1;                //enable serial port
	SYNC = 0;
	SPEN = 1;
	RX9 = 0;
	CREN = 1;
	FERR = 0;
	OERR = 0;
	TXIE = 0;
	RCIE = 1;
	//Include these settings
	GIE  = 1;  		//Enable global interrupts
	PEIE = 1;  		//Enable Peripheral Interrupts
	count = 0;
	count1 = 0;
	//configure lcd
	lcd_clr();
	while(1) {									//Do this infinitely
		if((myString[0] == 'L') && (myString[1] == 'U'))
		rotate_forward_LCD_1();       	    	//Run forward
        delay_motor();             		  		//Some delay
        breaks_1();                   			//Stop
		else if((myString[0] == 'L') && (myString[1] == 'D'))						//if data received, turn left mirror down
		rotate_backward_LCD_1();      	     	//Run Backwards
        breaks_1();                   			//Stop
		else if((myString[0] == 'L') && (myString[1] == 'L'))						//if data received, turn left mirror left
		rotate_leftside_LCD_1();    	  		//Run left
		breaks_2();         		  			//Stop
		else if((myString[0] == 'L') && (myString[1] == 'R'))						//if data received, turn left mirror right
		rotate_rightside_LCD_1();		  		//Run right
        breaks_2();         		 			//Stop
		else if((myString[0] == 'R') && (myString[1] == 'U'))						//if data received, turn right mirror up
		rotate_forward_LCD_2();           		//Run forward
        breaks_3();         		   			//Stop
		else if((myString[0] == 'R') && (myString[1] == 'D'))						//if data received, turn right mirror down
        rotate_backward_LCD_2();          		//Run Backwards
        breaks_3();       			  			//Stop
		else if ((myString[0] == 'R') && (myString[1] == 'L'))						//if data received, turn right mirror left
		rotate_leftside_LCD_2();	      		//Run left
        breaks_4();        	  		 	 		//Stop
		else if((myString[0] == 'R') && (myString[1] == 'R'))						//if data received, turn right mirror right
		rotate_rightside_LCD_2();	      		//Run right
        breaks_4();         		  			//Stop
		else if ((myString[0] == 'L') && (myString[1] == 'S'))						//if data received, left signal is lighted up
		led_signal_left();	      				//LED Signal light turn left
		delay_led();             		  		//Some delay
		led_off_l();							//LED Signal light off
		else if((myString[0] == 'R') && (myString[1] == 'S'))						//if data received, right signal is lighted up
		led_signal_right();	      				//LED Signal light turn right
		led_off_r();							//LED Signal light off
		else if((myString[0] == 'S') && (myString[1] == 'O') && (myString[2] == 'S'))			//if data received, emergency signal light will be lighted up
		led_signal_sos();						//Emergency light on
		led_sos_off();							//Emergency light off
		else if ((myString[0] != 'L') && (myString[1] != 'U') &&
			(myString[0] != 'L') && (myString[1] != 'D') &&
			(myString[0] != 'L') && (myString[1] != 'R') &&
			(myString[0] != 'L') && (myString[1] != 'L') &&
			(myString[0] != 'R') && (myString[1] != 'U') &&
			(myString[0] != 'R') && (myString[1] != 'D') &&
			(myString[0] != 'R') && (myString[1] != 'R') &&
			(myString[0] != 'R') && (myString[1] != 'L') &&
			(myString[0] != 'L') && (myString[1] != 'S') &&
			(myString[0] != 'R') && (myString[1] != 'S') &&
			(myString[0] != 'X') && (myString[1] != 'X') &&
			(myString[0] != 'S') && (myString[1] != 'O') && (myString[2] != 'S'))
		command_error();						//Command error
		delay_buzzer();             		  		//Some delay
        buzzer_stop();							//
		else if((myString[0] == 'X') && (myString[1] == 'X'))
			send_string("Welcome to");
			lcd_goto(25);
			send_string("SMART");
		else {
// ========== LCD CODING ========
void delay_lcd(unsigned long data)			//delay function, the delay time
{											//depend on the given value
	for( ;data>0;data--);
void send_config(unsigned char data)		//send lcd configuration
	rs=0;									//set lcd to configuration mode
	lcd_data=data;							//lcd data port = data
	e=1;									//pulse e to confirm the data
	delay_lcd(50);
	e=0;
	delay_lcd(50);
void send_char(unsigned char data)			//send lcd character
 	rs=1;									//set lcd to display mode
	delay_lcd(10);
	e=0;
	delay_lcd(10);
void lcd_goto(unsigned char data)			//set the location of the lcd cursor
{											//if the given value is (0-15) the
 	if(data<16)								//cursor will be at the upper line
	{										//if the given value is (20-35) the
	 	send_config(0x80+data);				//cursor will be at the lower line
	}										//location of the lcd cursor(2X16):
	else									// -----------------------------------------------------
	{										// | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
	 	data=data-20;						// | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
		send_config(0xc0+data);				// -----------------------------------------------------
void lcd_clr(void)							//clear the lcd
 	send_config(0x01);
	delay_lcd(600);
void send_string(const char *s)				//send a string to display in the lcd
  	while (s && *s)send_char (*s++);
Optimization can simply remove or simplify routines such as the following:
Obviously without the delay routine, your LCD routines would not function properly.
You can determine the exact cause of the issue by disassembling and comparing both the optimized and unoptimized versions of the code.
If the delay_lcd() routine is indeed the issue, then you maybe able to rectify the situation, by the inclusion of the keyword volatile in the variable data declaration.
However, specific handling of the keyword volatile is heavily compiler dependent.
Rewriting the for loop, could be another option.
BigDog
Would you be kind enough to upload a video of how you have modified the clock of your real hardware display and also how you manged to make it work out of spec?
You have already been advised to fix the delay in your code but you decided to "cheat" instead and tweak the parameters of the display taking advantage of the virtual environment so I was wondering if you found a way to "cheat" in the real LCD as well.
LaTeX Commands Quick-Menu:
