can anybody suggest me a direct method to build triangular structures in HFSS v9.0.
if there does not exist a direct method, plz suggest me some way to make it ,anyway!!
Draw the traingule using draw>line. Make sure in
Tools>Options>3D Modeler options: under "polyline" is checked: {Automatically cover closed lines}. Also make sure the polyline is closed otherwise you will not see the surface. The best advice is parametrized the triangule so you will be sure is closed.
i got ur point and it is a very lucid procedure, but i want to know another thing - if i need to have a triangular box other than triangular surface wat will be the procedure to make it.
hi abhi,
Its good now you can draw the triangular surface. Now, in order to draw the triangular box,. you need to sweep the triangular surface in the Z-Direction by whatever the amount of the box hight.
Your best bit to do that is to show up the net background, that would help you to correctly do it. Also, you should be carful about the direction of the positive or the negative Z-directions.
Regards,
Goher m_goher@yahoo.com
