Hi I have designed a simple LC circuit in HFSS under the Driven Modal solution type. How do I set the ports and how do I extract the L and C parameters of the components. Would also like to attain the Z Matrix. Could someone please help? Thank you!
It looks like you want to use a lumped port -- placement depends how you want to excite your structure. Is the source in series, or parallel, with this resonator?
