HFSS Model, Please help
Hello,
The thing is can anyone please check whether what I have visualized(design),because in the paper, only theory is given and no structure, so I have visualized the structure by myself.I want to know whether this is correct I have attached the HFSS design which I have done. Could anyone please check whether I have put the traces properly or not, Actually, in the paper, it is given that ground plane has thickness of 17.5 micro meter.
I make a sheet cutout using polyline. I need to subtract ground plane and poly-line sheet, Here it gives an error, only If i make thickness of ground plane as 0mm, I am able to subtract properly.
Regards,
Avin
