E(x,y,z,t) = Epeak(x,y,z) * cos[wt + phi(x,y,z)]
I guess HFSS is using Epeak(x,y,z) in case of magE. Using animation the cos-term is multiplied.
Does anybody know the difference to cmplxE. In the latter case, animation is not possible, result does not depend on time.
MagE is a complex number. "Mag" here indicates the vectorial magnitude, ie. sqrt(reEx+reEy+reEz)+i*sqrt(imEx+imEy+imEz)
ComplexMag is a real number, and it is the absolute value of MagE.
MagE is a complex number so it can be animated wrt time.
ComplexMag is a real number, it cannot be animated wrt time.
This answer is not clear. It is better to look at their definitions:
Mag_E is defined as Mag(AtPhase(Smooth<Ex, Ey, Ez>, Phase))
ComplexMag_E is defined as Mag(CmplxMag(Smooth<Ex, Ey, Ez>)) or Mag(Smooth<Ex, Ey, Ez>) in new HFSS versions
Both two parameters correspond to Etot due to the Mag() operation.
The difference between Mag_E and ComplexMag_E can be simply described by the equation: Mag_E = ComplexMag_E * cos(Phase)
Hi, but then the CmplxMag result should be identical to at least one MagE result, but this is not the case ?!
-e[/QUOTE]
It is. Taking a rectangular cavity resonator working at TE101 mode and excited by 1-V/m E-field with 0-deg initial phase for instance, you will see the Mag_E@0 deg is the same as ComplexMag_E, and Mag_H@90 deg is the same as ComplexMag_H.
It is. Taking a rectangular cavity resonator working at TE101 mode and excited by 1-V/m E-field with 0-deg initial phase for instance, you will see the Mag_E@0 deg is the same as ComplexMag_E, and Mag_H@90 deg is the same as ComplexMag_H.[/QUOTE]
Hi Streamlet,
Do you think ComplexMag_E will change across location? My understanding is if it is travelling wave, it will be constant across location. If it is standing wave, it will show "phase" across location, because the amplitude itself is indeed dependent on location.
However when I created a microstrip with reflections at both ends to demonstrate the standing wave effect with ComplexMag_E, I failed. Can you please review my thread "Plot field of microstrip" and give us some comment?
