[SOLVED] HFSS Large mesh warning
jasyong
Newbie level 2
Newbie level 2
Hi guys,
I have this warning in HFSS.
"[warning] Solving inside a solid with high conductivity may require a large mesh"
Is there anyway to solve this issue and have no warning at all ?
I have tried increasing the "Max elems" count but that does not seem to work.
View attachment CPW.7z
Thank you in advance.
You can uncheck the solve inside box for the high conductivity materials. Large mesh is only an issue if your sims take too long or are too big to run on your machine.
Thank you.
I am in the impression that I am required to apply should sort of mesh operation to solve the issue.
The simulation did take slightly longer but was still tolerable
