HFSS : how to subtract polyline structure from a box in HFSS ?
sarmad0107
Newbie level 3
Newbie level 3
Hello
I am trying to subtract a polyline (diamnon shaped) structure from a box but I am getting this error message "Solid blank is unaffected by sheet tool in subtract operation" and unable to subtract. Can anyone please suggest me that what should I do in this case ?
Thanks !
Sounds like you are trying to subtract a 2D object (your polyline object) from a 3D object, but I might be wrong. Are you sure you have a 3D object (your diamond)?
Hi
thanks for your prompt reply.
Yes my polyline structure is 2D and box is 3D. I know that 2D and 3D structures can not be subtracted. So can you please suggest anything else so that I could do same task.
Many Thanks
Here I have attached my hfss file.
Please check it and make necessary operation in order to cut diamond shape from box (patch).
Thanks!
  • diamondCut.rar
Again, subtraction works with the same dimensions in the same space (2D obj. should be arranged on the same plane)
Therefore you should either find a cross-section of your 3D box with the poly-shape's plane, or extrude your poly-shape to some kind of 3D object. The capabilities of HFSS in the latter are limited. If you want non-linear extrusion, you should use some external 3D CG software, like 3DMAX etc.
