fwbsys
Newbie level 3
Hi all,
I've simulated a cylindric volumina and now i want to plot the e-field at the surface of a cylinder with a varying radius. (Coax Line) ... for the inner and the outer surface of the dielectrica its easy to plot it, i also used clip plane (but as the name says, this only works with planes).
Does it work with the "fields calculator"?I've read this fields calculator cookbook but i haven't got it to work. Anyone an idea? or an example for dummies?
I'm using version 12.0.1 of HFSS.
regards,
fwb
regards,
fwb
