orsamoo
- Joined
- Oct 13, 2013
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 1
- Trophy points
- 1
- Activity points
- 52
Hi
I am making my first steps in hfss and want to calculate Q and L of known coil in order to understand the process.
my coil is a very simple flat coil:
this coil is a flat coil, known dimensions and properties. I have read the hfss spiral coil help file and did the same just with this coil.
instead of designing round corners I mad it sharp (rectangular coil with same dimensions - I belived it would change the result slightly).
the problem is that I am getting 100-300uH inductance instead of 10uH in around 125Khz....
I noticed that when I changed the ground (the rectangular cube where I connected the 2 ports of the coil to) size it also changed my inductance - this tells me that something is wrong.... why is it what am I doing wrong?
additional info - even when I did a ring ground as in the example the result was far from reality - I know it because the Rsestance that I can calc pretty easy was far from real...
what can be the reasons for such wrong simulation?
thanks for any help.
