jhuthz
Newbie level 3
HFSS Filter Question
I'm designing a window-ed nickel sheet which will transmit certain frequencies and reflect others. I also want to vary the angle at which the radiation is incident upon the sheet and see the effects.
I know that if I want to assume an infinite array I should Floquet ports. If I want to use a finite array, what ports should I use and what settings should I use?
