I've been successful in radiation a field upon surfaces imported via .stl and have plotted the J Fields onto each surface and would like to get these values as x,y,z,Jx,Jy,Jz or similar. Using the fields calculator I select from the library Vec : Vector_J and export using a defined .pts file and the resulting export is a .txt with the correct x,y,z columns followed by NaN NaN NaN columns. To get NaN the pointcloud is in mm but upon other threads I've seen meters might be the correct way but this results in just an output file saying "Complex Vector data "<Jx,Jy,Jz>"" and that's it. HFFS also seems to almost crash in trying to export using the meters pointcloud if that's at all relevant.
Using the min,max,spacing export onto grid file where the units are explicit also results in NaN for the calculated values.
