May 14, 2008 #1 M myem Full Member level 2 Joined Dec 12, 2003 Messages 127 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 972 touchstone format when I finished simulating in HFSS , how can export the S-parameter in touchstone format ? thanks
May 14, 2008 #2 G ghb Advanced Member level 4 Joined Jul 15, 2002 Messages 116 Helped 19 Reputation 38 Reaction score 13 Trophy points 1,298 Activity points 835 touchstone hfss really you should use the help files in hfss but in the newest version right click on setup which is under the analysis tab in the project tree; click on matrix data, check the options you would like and then export to touchstone. pretty easy.
