ywzhong
Newbie level 5
the lumped port can't touch the ground in my model,I have trid to expand the port, but it still get the error:
"Fast sweep setup, process hf3d: '1' conductors touch lumped port '1', typically a lumped port contains 2 conductors. Please verify conducting boundaries and objects are correctly assigned and touch the port. If a Radiation boundary touches the port and it is desired for use during the port solution, select 'Use Radiation Boundary on Ports' under the Advanced tab in the Solution Setup"
I attach the model and there is only one port in it . I have no ider how to do and get puzzled, please help me.
