Mona Fouad
Newbie level 5
- Joined
- Apr 25, 2014
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Egypt
- Activity points
- 64
Dear all,
I need some help, I am trying to simulate on chip differential pair with certain stack with 7 metal layer above substrate (M7: differential pair signal , M1: is sheilded Ground of this diff. signal then under M1 , there is a substrate.), to export S-parameters from HFSS and import it to cadence.
but when I simulate it with substrate using driven terminal, it gave me warrning "Port refinement, process hf3d: Port '1' has 3 signal conductors with 2 terminals. More signal conductors than terminals can adversely affect the terminal transformations. Please verify conducting boundaries and objects are correctly assigned and touch the port" .
if I simulate same design without substrate , I wouldn't have this warning.
How can I solve this problem?
Also, it's better to solve it in Driven terminal as I did or Driven Model will give more accurate solution?
Thanks in advance.
Thanks in advance.
