ferdinnand
Junior Member level 3
- Joined
- Oct 12, 2010
- Messages
- 30
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 1,525
Hi all,
I'm trying to model a rather ripped coax cable which has a particular region of 10mm in the middle, where the outer conductor is stripped off. In reality, both ends of the cable would be connected to the ports of a network analyser so that they'd have a single reference ground. Yet in HFSS, I cannot find a way to assign a common ground to the structure. As you can see in the picture I tried to put a perfect-E rectangle (in blue) just outside at the ends of the outer conductor but that of course inserts its own parasitic inductance, and much worse, depending on the width of the rectangle. Here is what I get as reflection from north to 1GHz;
.png
My question is how to create an ideal model in HFSS to connect my ground conductors at both ends of my coax without adding parasitic inductance ?
PS: The reason behind my intention to simulate such model is to find out a proper way to combine several ground conductors in one of my package design projects having lots of ports with separate grounds which have to be combined somehow. So in terms of pure imagination, what I'd like to have basically is a zero-length conducting path model if possible.
.png
