Hercules DRC error: PO.RL.1: ALLPOLY maximum length = 200000nm (after poly_sub cut)
shavakmm
Member level 4
Member level 4
Bangalore
I am getting below error in Hercules DRC run. Can anybody explain about this error and also how to solve this?
... 2 violations found
ERROR DETAILS
#####--- ERR_SELECT -----------------------------------
SELECT_CONTAINS ALLPOLY_CUT {
COMMENT = "PO.RL.1: ALLPOLY maximum length = 200000nm (after poly_sub cut)"
WIDTH=200.0001
HEIGHT=0.0001 } (320;19)
Structure ( lower left x, y ) ( upper right x, y )
XYZ_TOP (401.536, 2.160) (401.572, 333.540)
XYZ_TOP (401.654, 2.160) (401.690, 333.540)
It seems like you have exceeded the maximum length for a POLY path in your design
