dear all
i want to make a true rms to dc converter to design a "True RMS AC voltmeter" in which the input voltage can be any type of signal like triangular,square or sine etc..and the output should be a dc voltage.i am sending the link of file in which there is a circuit of the rms to dc converter. please help me out to make it work.
also i cant use any costly ics like max536 or lt1966 etc.becuase of cost factor.
When your frequency is limited (near 100Hz) you can use microcontrollers such AVR. They have an ADC integrated in them. You should get many samples from your input signal and to have good precision. your ADC freq. may be near 10 times (1MHz) of original signal with 6 or 8 bits. then your program is work. after getting a new value micro squred and added it to others; countinuing this routine as you think sufficient and other steps to finalize the results then send this to LCD. a micro like Atmega 16 is good choice for beginning
FYI.
If the sinput sigal is a periodic one, there is a simple way to convert its rms value to DC describing as following:
Employ an AC amplifier to amply the input signal to make sure the output level is above 0.7v, higher amplitude is better. The amplified large signal then is fed into a diode ring mixer as a local oscillator(LO). The input signal is also fed into the mixer and it will be mixed with the LO signal. The DC product of the mixer indicates the RMS value of the input signal since it was multiplied by itself with a factor inside mixer. You can employ a low-pass filter to filt out the DC value from other mixing products(ripple).
try these refs. audio amateur 2/83 Rms AC Voltmeter with db converter
by Chares Ulrich
Modern electronics, June,1985 By john t Bailey
If you absolutly need a dc out put try puting an rf probe on the out put.
These designs use the AD536AKH from analog devices, it's abit pricey but low parts count and the cheepest way I have found.
