help !!!! Xilinx i4.1 sp3 install problem
kairi_mai
Newbie level 1
Newbie level 1
a error message "A valid $XILINX environment cannot be locate and is required to load the xilinx software" to hold install sp3.
how to set $xilinx?
help!!!!
ths
This environment variable points to the root of your Xilinx installation. For example (Win32 system):
XILINX=c:xilinx
Set the environment variable (the right way for your host OS) before applying the service pack.
Hi kairi_mai,
To set up your environment variable in w2k (i.e) go to:
System Properties -> Advanced -> Environment Variables -> and here add a new variable called XILINX pointing to your top ISE folder (C:XILINX or wherever you installed it)
I hope it helps
Maestor
Hi kairi_mai,
I have xilinx foundation 2.6i but I want upgrade my program to xilinx 4.1i could you more specify the web where i can download
thank you
