joecool21
- Joined
- Jul 25, 2013
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 36
Hi all, In the past I used ISE 9.1 and a Diligent Jtag-USB JTAG cable to programing a x9500 CPLD. I upgraded to ISE 14.X, Windows 7 and the latest ADAPT software after which I'm unable to program the CPLD.
The cable is listed under USB device, Impact does not recognize that a cable is attached ADAPT does.
Using IMPACT, the program file is xxx.jed while ADAPT uses a xxx.svf what is the different?
ADAPT will only except a xx.svf file, Can a SVF file be created by the ISE?
Is there a low cost USB cable solution for programming a x9500 CPLD that's compatible with later version of ISE?
thanks
thanks
