Help with TL494pwm !!!!
Alian
Junior Member level 1
HI for all Iwant to build swich mode power supply with Full bridge design using irfp460 (4 transistors) and TL494 pwm And ferrite core ETD54 n27 frequency 80Khz And with current adjustable and I want the circuit without driver transformer for mosfet Gate Please any one help me for build the circuit(without driver transformer)!!!!!!!!!!!!!!!!!!!!!!!!!!!
thankyou very much please if do you can to put circuit diagram to clear this idea
here iam having inverter schematic in the o/p stage tl 494 is used to drive full bridgefor smps you should use 2 tlp250 at tl494 o/p stage
  • full bridge .pdf
thankyou very very much for this circuit and Ihave one question if Iwant to connect TL494 for inverter welder with 2 tlp250 what is the suitable circuit for this sorry for alot of questions because Iwant to understand everything about this circuits and this ships
