Greetings ... a couple of days ago I have been spending a project done in Vivado 2017.3 to ISE 14.5, because it is required to adapt it to a Virtex5 device. So far I have managed to adapt it and be able to synthesize it, but now I need to simulate the operation of the system using Modelsim SE 10.5. The problem is that the simulation code that was used in Vivado is made in SystemVerilog and it is not possible to use this in ISE.
Is there any way to use this simulation code in ISE without the need to translate it? Any help is very welcome, thanks in advance.
